Another Cutter Grinder
All kinda good info going on in here. Looks good. You would not happen to have any more pics of how you set it up in the lathe would you?
I am planning on building a balancing system into the mount. It worked wonders with my 8" pedestal grinder.
That should work fine Mike. I am nearing the end of my build.
"Billy G"
Chuck, those are all the pictures I have of that setup. In the second one, you can just see the end of the lathe spindle. The grinder spindle pulley end is 5/8". It is in an MT3 collet in the lathe. The actual cutting was done by an MT2 tapered reamer. Just a skim cut to try to even out the runout.
