All I can say on this issue, is with the dial indicator, when using the micrometer stop, you watch the dial indicator, and as it is aproaching the zero point, you disconnect the feed a little before the zero point, and hand feed it againist the micrometer stop. I have had zero problems with the stop, and my hourmeter reads 264 hours, I made it probably 10 hours after I recieved the lathe, so if I figure using it even 1/3 of the time I have used it 70+ hours with NO problem. I also need to second the post earlier on how amazing this lathe is! I would be to shy to show you the pictures, I have over the last 1 1/2 year, on the large turning I have done on this machine! A whole bunch of turning for work on 8" bushing's used for the heavy eq. company I work for!
Bob in Oregon
