I finally got my new 6x12 fine pole magnetic chuck today!:ups:
I spent the evening getting it set up and ground it in. This machine is now ready for action.
The things I had to obtain to get it how I wanted it.
* A hydraulic power pack.
* A new lubricator pump.
* A Kool Mist system.
* An Acu-Rite display to work with the scales that were already on it.
* A new pressure guage for the Hydraulic power pack.
* Misc. fittings for the hydraulics
* A few new grinding wheels
* A diamond dresser
* A pin wrench for the wheel adaptor.
I still want to dial in the hydraulics a bit better. Theres a couple of flow valves under the left side of the table that need to be adjusted to get the right stroke running about the same speed as the left stroke. Right now I got them both wide open. Theres also a bypass valve on the powerpack that I can crack open a bit to quiet down the pressure relief valve...I have to tweak that a bit. I might remove the ugly accumulator on the power pack too. I'm not sure if the accumulator is a good thing or a bad thing yet. I'll try it without it and see how it goes. I'm thinking that it smooths out any pressure surges, but who knows if it really makes a difference.
This is gonna be a good machine.
Marcel
