Nice spider and tach install.
Noticed in the photos you have lots of the small black specs from the factory belt. Recommend replacing it with a Gates 5L280W to use on the "B" pulley section, and a Gates 6970 for use on the "A" . They run smoother and actually slightly quieter... several guys have had problems with the factory belt basically shredding after about 10 hours or so.
They also give you a slight bit more room between the motor and the lathe.
