- Dec 21, 2018
- 2,222
I've been considering these (annular cutters.)
But have zero experience with them. I see they typically come with a guide pin. 1. Is it necessary if using a mill or lathe?
2. How do you get the slug out of the cutter?
3. The plan was to buy an MT3 adapter to use the lathe and just use 3/4" collet on the mill. OK?
First use is a series of 2" holes in 1/2" mild steel on the mill.
4. Do you use power down on the mill? Do you have to retract/peck often?
5. My mill & lathe are both 3 hp, I'm assuming that is enough for 2" diameter in steel.
6. For hobby use are the Chinese sets OK?
7. I plan to use cutting oil.
Thanks
Thanks
