- Feb 18, 2016
- 451
I wanted to cut down a tree today to make into lumber, but my log-lifting tractor was broken. Boo boo.
A piece that holds a chain for the 3-point hitch had broken off.
Should be a simple fix right? It took 5 hours to fix it.
The first thing I did was take the pieces off as well as the unbroken piece on the right side to use as a pattern.
Then I had to find a piece of steel the right thickness. I found this old Jeep step:
It even has a hole already drilled in a usable place:
Drew the outline in chalk and headed over to the plasma cutter.
After cutting the part out and grinding it down some I drilled holes using the unbroken piece as a pattern
Finally, after drilling all the holes I was able to mount it back on the tractor and it fit perfectly.
5 hours to do this little tiny job. But now I can lift logs again. Yippee!
