An engraved bronze chariot plane I made
Great piece. I would love to get into doing some engraving I just love the look it gives to the pieces you have. :tiphat: My hat off to a true artist. Any chance of some basic how-to for someone wanting to try some simple engraving? :)
Jeff
Back when I made that plane,I was just using slim triangular files with the ends ground to made an engraving chisel. Cut off the tang,and wrap the file in string to keep from wearing your hand out over the naked file teeth. After hours,the teeth can begin to be uncomfortable,plus the angular corners of the file.
I used a small chasing hammer,which I also made,to drive the engraving chisel along. Every hammer tap moves the chisel a very small amount,allowing you go go around curves smoothly without leaving a series of little straight lines connected together,if you see what I mean.
I can get by with just drawing the basic "C" and "S" curves to fill the spaces properly. I go freehand from there,but I warn you,that takes lots of practice. What you want to do is fill the spaces evenly,with no places that are too sparse,OR too busy. You need to de able to draw well,to make the C and S curves,and the other details look proper. If you can't draw,you can't engrave.
Later on,I made proper engraving chisels(known in catalogs as die sinker's chisels) from HSS,which I bought as ANNEALED 3/8" squares from Latrobe,and hammered at only a blood red heat into the tapered chisels I wanted. The chisels were not further heat treated,and though this is not the correct way to harden HSS by any means,it made the chisels very hard,but also MUCH tougher than the normally rather brittle(for this application) HSS. If you want to buy decent steel,buy some 1/8" square cobalt HSS,and mount them into straight 1/2" dia. handles. One of the greatest gun engravers taught me that,Lynton McKenzie. He is now dead,but did incredible work,and was a good friend.
Excellent work on the plane George, it definitely has that "labor of love" look. I like the look of the bronze and rosewood. Thanks for sharing it with us.
I've done hand checkering in metal and wood and have always wanted to try my hand at engraving. How long did it take you to engrave the plane? Did you do both sides, or just one for the camera. ;)
Tom
It was years ago,but I don't think the engraving took more than 2 hours. It's like drawing. You either can do it or you can't. If you can draw,the foliage comes easily. Engraving block letters is harder,because every little mistake shows up really big.
I just realized the alloy should read 90% copper and 10% tin,rather than 80% copper. Maybe Nelson will see this and correct the article. Sorry.
Thank you,Nelson,for correcting the alloy to 90% copper and 10% tin.
P.S.: I just read that Tony Wells has taken over the forum,so perhaps I should be thanking Tony ? Anyway,thanks to who ever fixed it.:)
George, it wasn't me, this time, but I sure whoever did it was glad to help.
I fixed it, before I removed my admin/mod privileges.
Nelson
