- Nov 15, 2016
- 943
Ericc,
Have you visited your local welding supplier? Aluminium welding flux is pretty common. Check at an airfield or good ships chandlers, plumbing supply store. The only things you really need with Oxy/Acet. is a Stainless Steel wire scratch brush - that will NEVER, EVER be used for anything but cleaning Aluminium. I just looked at those Tin Man welding lenses, out of my price league. I use standard gas welding lenses with a gold filter, not as good as the old Cobalt but for small runs fine. You can also use an auto darkening arc welding helmet if you play with the shade settings. Clean the rod with a bit of wet'n'dry paper first so it is shiny.
Think about WWII and the people who were welding up aeroplanes. Many of them didn't know what a welding torch was until they were put to work. If you can gas weld steel you can gas weld Aluminium. Drop the gas pressure a bit,(unless using a Henrob/Cobra torch),go up a couple of tip sizes, use a slightly reducing flame and lift the flame off the work regularly.
20 minutes practice on some scrap should see you laughing.
