You say yours is 1/16 low? I just bought the same set up and it is low as well. The adjustment nut wont raise it high enough before it bottoms out to get the cutter in the center of the work piece. I have an old aloris piston style holder, do you as well? The only thing I see to remedy it is make a spacer plate to go under the tool post. What is your set up and did you figure out how to remedy it being low?
