Align Z axis power feed install TV950
use studs in the plate instead of screws.
I only had to drill and tap one hole in the black hockey puck. Easy enough. To the point where I just need to set up the limit switches.
I can’t provide photos right now as we are headed out to Yellowstone and will be gone for a bit over two weeks. But what I did was to figure out how I wanted positioned and marked the mount so that I could get the clearances and position that I needed.
I have to say, I really like it. What a difference In positioning the table in a vertical position. If you don’t have a power feed for the vertical, save the money and get one! It’s really worth it!
Here's a thread of my installation of a Z-axis power feed on my Bridgeport (BEST money spent after a DRO). I had to modify the mounting adapter. My BP is CNC, so did the work on it.
Bruce
