Do you have any places near you where you could have it hydro tested?
Not really, i'm sure there is some company in skopje, next city over but transporting and paying for testing this big of tank will be a big hassle.
Sometimes they'll come to your location. You can also test it yourself; Fill the tank completely with water, leave no air, then pressurize it to double the working pressure you can use a high pressure air pump or a scuba tank to do this, possibly a pressure washer but you have to be careful not to over pressurize it. If the tank bursts it will just split and the water will gush out, it won't explode as water cannot store energy. Test the tank every few years.Not really, i'm sure there is some company in skopje, next city over but transporting and paying for testing this big of tank will be a big hassle.
Not sure about CO2. because it can dissolve into water it might make a lot of seltzer and that can store energy... I would think an inert gas like Argon or Nitrogen would be a safer bet.Good advice Eddyde, could i use compressed CO2 with a regulator from my welder to test the tank?
I mounted my air comp outside in its own little shed, unconnected to my shop, except for electric and pipe lines; doesn't take up shop space and is much less noisy.
