First of all thank you to all of you that chimed in with suggestions. They all were very helpful and informative. Now there's a twist to this saga. Because it was so cold outside this morning (~20 deg F) I decided to wait until this afternoon (~40 deg F) to remove the motor. I flipped the breaker and as I always do I turn on the equipment to make sure I opened the correct breaker. Well as it turned out I opened the wrong breaker and when I turned the compressor switch on it started up and continued to run as it normally does. WTH!? This is good because I really didn't want to buy a compressor motor. So when all else fails you read the instructions, right? I dug through the owner's manual and it says in extreme low temps you can use 10wt non-detergent oil or 10-30 synthetic oil. Got to thinking that the low temps and the 30wt oil was like pumping mud. This is the second winter in my current home and I don't remember having problems like this last year. Whatever! Tomorrow I'll get some 10wt compressor oil or 10-30 synthetic and see how that works out. I'll keep you posted.
