My Husky 60 gal. air compressor has worked flawlessly for years until a couple of weeks ago. When I turn it on the motor starts as it should then starts to slow down after a few seconds of run time. If I open the air line drain down stream of the tank the motor speeds up to operating speed. I close the valve and the motor slows down and if left on the motor stalls. I'm not sure if this is a motor problem or something else is causing the motor to stall. If it's the motor is there a way to check it out without sending it to a motor repair shop? Could it be the tank inlet check valve, the unloader valve, or ??? For info the compressor is located in a small closet outside of my shop. No insulation and the morning temps have been in the low 20's F. and the high's in the low 40's.
Here's a photo of the motor data plate.
