- Apr 29, 2019
- 2,299
There may be a backlash adjustment on those screws. If there was any more than a half turn of backlash in the nut it would mean that the nut is completely stripped out with no thread remaining. If you look close you may see that the screw is moving in and out while taking up the backlash, It is just not possible to have that much backlash in the threads. This may be a good bargaining point to get the price down a bunch.
It could be as simple as tightening up a nut on the end of the screw or adjusting preload on the bearings to remove its free play. But there should be an adjustment somewhere.
Once you have that adjusted then you can acess how much backlash is actually in the nut, It could be a nice little project to make new nuts if they are really needed. Always love the concept of a machine making its own replacement parts to make it better.
Unfortunately it is far away so not easy to go check it out further.
