One other advantage I like on the collets, particularly the 5C set up that I use, is that you can hold square or hex stock in them.
Another is that I can take a project from the lathe to the mill, and using the square or hex collet blocks quickly index a part to mill flats on the part in 1, 2, 3, 4 or 6 divisions.
Downside to them is the time taken to change from one collet to another. Lots of spinning on the chuck key on my bison collet chuck to remove or insert new callets, and as others have pointed out, you need a lot of collets to cover the full range of 1/64" to 1-1/8"
I got a 5C collet stand 72 holes that was double plate construction and used each plate in a drawer of a roll cab so that I can store up to 144 collets.
First drawer is for imperial rounds by 1/64th increments, second drawer is for metric rounds by 1 mm increments, hex and square by 1/16th increments.
Walter
Walter
