Adjustment Needed?
Your cart looks pretty sturdy and if you're looking for a quick fix then make or buy some leveling feet, not so much to level the cart but to get the whole thing solid on the floor. You can attach the feet (you know, the screws with pads on the ends) to the sides of the cart and hopefully that will be solid enough and still enable you to move it at need. What you need is a solid base upon which the lathe can be leveled. Again, by that I mean both ends of the lathe being in alignment so there is no twist in the bed and if you have that then you're good. The cart itself does not have to be level, although you will find that if you move the lathe around the cart itself will twist and so will the wooden base and this can introduce twist in the lathe bed. That's why a cabinet that doesn't move around is better and a metal base is even better as it doesn't move with changes in humidity.
The bolts you mentioned are intended to lock the lathe down to the surface it is sitting on. In order to level the lathe you will need to use shims near these bolts. Many guys use horseshoe shaped shims and the bolt passes through the center. I hate the tedium of working with shims so I would personally get some 1/2" plate; drill and tap for 2 heavy bolts in each plate and inset the plates into the top, one under each end 0f the lathe, so the bolts can be used to dial out the twist in the bed. You can then use the lockdown holes to bolt the thing down.
If you're going to do mainly wood turning then this may not be necessary but if you want an accurate metal turning lathe then you are going to have to level it.
As an aside, I know a 98 year old plantation machinist. He turns huge bowls on two big engine lathes. He lag bolts the bowl blanks onto his faceplate and winches the thing into position. He makes the most beautiful bowls, larger than most turners can make. This guy throws a fish net for dinner 3-4 times per week and plays the Sax every night. Still sharp as a tack but getting a bit deaf! They don't make 'em like they used to.
Mikey, thanks again--that gives me some ideas to work on. I just watched a vid of a guy leveling his lathe by adjusting the leveling foot on his bench (he showed testing the level with a plumb-bob, it was amazing how little twist amounted to 5 thousadths difference from one end of the bed to the other).
I hear you about giving up the rolling aspect of the cart--I assume every time it is moved, it would have to be re-leveled (and it does tend to get moved).
I mostly turn wood (a wood lathe is on my wish list), but as in this case, I do see a need to accurately turn metal from time to time. Here is what I was working on--my goal was to make two sets of parts out of five inch pieces of .5" stock. Of course, I was measuring at the tail stock end and only too late discovered my taper problem. Ended up re-doing a couple of them. The bigger ones are .420 stepping down to .245 and the smaller ones are .333 down to .245 (well, that's what they "should" be, but these are within a couple thousandths and close enough for their intended purpose which is as bushings to turn pen barrels between centers).
You're welcome!
Your bushings look good and if they fit then that's what matters. I think it is very cool that you are able to do it in the first place - most wood workers cannot.
I saw that pendulum video - pretty cool. If you try it, let us know how it goes.
Hang in there, Mike. You'll work this out. Maybe when you get your wood lathe you can find a spot for your 12" lathe to sit and really get it sorted. In the meantime, please ask questions. There are some great guys here and we all enjoy sharing.
You're welcome!
Mikey, thank you. Though I wouldn't call myself a wood turner yet as all my pens and other wooden odds and ends have been turned on said 12x36 using the same cutter I did the bushings with--honestly I've never held a skew or gouge.
The metal lathe makes turning more-or-less straight walled wood projects easy, and I use the power feed. It does, though, make tapers like the ends of pens or "creative" shapes rather difficult. I end up using files and sandpaper to get the tapers I need.
I think having both the metal lathe and a wood lathe will be the ultimate answer and I will at some point get both solidly mounted. Thanks again for your help. Here's a pic of one of my pens (Bocote with a CA/BLO finish):
PS: I use the lathe to drill the blanks, true up the ends (with a disc sander I made for the head stock) and to assemble them using wooden (more-or-less) Morse tapered inserts I made for the head and tail stock for a press.
That's a really nice pen, Mike! You might think that something like that is simple to make but most people cannot do it. I would be proud of that if I were you!
You may not be aware that you can turn metal just like you can turn wood. The tools are called Gravers and allow you to turn and carve metal just like wood, including hardened materials. It does require a hardened tool rest but the gravers themselves are simple to make and use. Sherline has a pdf about gravers as made by WR Smith if you are interested. Mr. Smith also produces some videos on the subject, too. If you do make some gravers you will find yourself using them on almost all your lathe metal projects; they can add a subtle touch to your work that shows your craftsmanship. Check it out.
First, great work on the pen! That's very nice. :encourage:
Second; this statement caught my eye.....
I think I've got my tail stock alignment pretty g00d (at least as good as I can get it by eye-balling the two centers.
Besides leveling the lathe (or really avoiding the bed twist) above, tailstock alignment is also important. Cutting tapers is exactly why the tailstock is adjustable. The eyeball technique was likely good enough for wood turning. However if you are now measuring to thousandths of an inch it may no longer apply.
Turning a part, measuring the taper, correcting the tailstock, and repeat is one (slow) method of adjusting the tailstock. Tubal Cain does it here:
You might consider acquiring some more precise measuring tools. Like everything else there are options, you can trade off cost, precision and easy of measurement. Faster tailstock alignment could be done with:
1) a dial indicator
Commonly just called an indicator or a "clock" these have a round face and a stem. The stem has a central plunger that moves in/out. A spring pushes it out, and any inward movement is shown by the hands on the round face or on a digital display. Different indicators are marked in thou. or half-thou. and the total movement of the plunger might be only 1/2 or 1 inch. Often there are two hands, the long one measures thou. and the short one measures the number of full turns of the big hand. There are many different mounting arms, magnetic bases, etc. available. They can be mounted either by a little boss on the back, or clamped around the little stem.
These are among the most used measuring tools on a metal working machine. You can measure lathe spindle run-out, mount one to a carriage stop as a travel indicator(http://www.hobby-machinist.com/threads/double-duty-micrometer-stop-project.34769/). For centering your tailstock to your headstock you would mount the indicator to something in your headstock(preferably in an accurate collet), measure against the shoulder on the tailstock center and manually rotate the spindle at least 180 degrees from front centre to back center. Note the face of the indicator will be moving too, so some rubber-necking or a mirror can help. Adjust the tailstock location (front/back) until you get the same indicator reading on the front and back.
My local used tool place has some new-old-stock (made in china) enco dial indicators at less than $20 apiece.
Here are some examples:
http://www.leevalley.com/en/wood/page.aspx?p=32525&cat=1,43513,51657,32525
http://www.leevalley.com/en/wood/page.aspx?p=51598&cat=1,43513,51657,51598
http://www.leevalley.com/en/wood/page.aspx?p=71664&cat=1,43513,51657
2) a dial test indicator
Resembling a dial indicator with a small lever at the end so that rather than measuring linear movement along the stem it measure deflection
These often have a little dovetail on the back and are held with a matching dovetail holder with a round pin for a mounting arm. These have very limited deflection, but can measure in either direction. These are often used to mount a vise to a mill table by putting the indicator in the vertical spindle and running the indicator along the fixed jaw by moving the table back and forth. The vice gets bolted down when the reading it the same from one end of the jaw to the other.
http://www.littlemachineshop.com/products/product_view.php?ProductID=1249
3) co-axial indicator
Some see this as the best option for aligning two cylindrical parts......but they can be expensive, and therefore many people just use the above instead. These are very handy for aligning a vertical mill spindle with an existing hole or boss on the work piece. One advantage of them is that they have a little arm that stops the gauge face from spinning. No more rubber-necking or mirrors.
Whatever you hold the indicator with could add to error, if it is attached to a bar held in a 4-jaw chuck where the jaws are not centred to the lathe spindle, you could end-up either setting the tailstock wrong, or never being able to zero it!
-brino
Hmmm--I think I've got my tail stock alignment pretty g00d (at least as good as I can get it by eye-balling the two centers.
Regards,
Michael
Pinch your 6" steel machinist's scale horizontally between the centers and adjust the tailstock until it is perpendicular to the ways.
"Lathe centering buttons are very easy to make on the lathe."
Not my idea, rather a quote someone else posted.
I hadn't intended to repost this so didn't save an attribution, sorry.
I googled it not knowing what it was and plan to make myself a set as it's simple to use and appears it would be very accurate.
Mike
It appears that the taper is present, with and without using the tailstock.
