Well the 17" drill press from HF showed up. I had called their info line and was told a 43389 had shipped. my receipt said 61484.
When the store worker brought the box up it was a 61484. I got it in the garage and started checking things out a few findings:
The motor is a 7.5 amp not 13.5 amp.
Aluminum pulleys
Aluminum main table support as well as the column surround
The main column support that bolts to the base is Aluminum as well
The main column is .060 " in wall thickness. That is NOT a misprint. That is thinner than most exhaust pipe tubing- Not thrilled
I checked the spindle support run out side to side as .005 total. ~.008" all the way extended.
The motor slide pins allowing belt tensioning are a loose fit allowing the motor to move around in the vertical axis before belt tensioning.
Started up the machine and I had forgot to remove the 1/2 thousand's indicator.
Within 3 seconds the vibration shook it off the NOGA and it hit the concrete floor. breaking it DOH.
At least it was not an expensive Name brand indicator.
I checked the pulley set screws which were never fully tapped, so it was allowing the motor pulley to move on the shaft . Re tapped much better and tight. Had some better quality belts in my stack of used auto belts than what was supplied and got it running actually smooth.
Not sure I can deal with the super thin "column" or the aluminum support pieces.
I did some looking on reviews and one guy pressed a bit to hard drilling and the aluminum collar column piece fractured into two pieces. ( He posted the pictures)
He then had an extended wait for a replacement.
The manufacturer also left the table up down rack gears un shimmed which makes the rack and pinion basically unusable until they are re shimmed.
I now DO believe the comment section on HF site comparing the two SKUs.
From the more powerful 13.5 amp motor, to the all cast Iron support, better castings, tighter motor slide pins, and likely superior run out numbers.
Really not happy with the column thickness and the aluminum work table support.
I was irritated enough to walk away from the new drill last night and not much better today. I may re shim the rack drive and mount it then press the chuck in and see how badly the table and head deflect.
If it is not bad and the aluminum casting does not break will probably keep it.
If it does deflect or the casting cracks, back it will go.
May even just return it and buy the 20 inch that weighs 300lb.
Still really happy with my HF knee mill, 1224 HF lathe, and even the little 7x10 HF lathe, but some of the cost cutting measures on this drill press are possibly a step to far.
