- Feb 8, 2014
- 11,176
If it is a brush type AC motor (Universal motor), then a router speed control will work just fine. A router speed control is pretty much a light dimmer with a little more circuitry. The technical term is Phase Angle Control. On the low end, about $15 from HF. The speed control is OK, but not great. I have used these on my router and other universal motors without problem. I did a quick search, and was not able to come up with a plug in 120V PWM controller.
If you want to spend the money, then a DC motor controller is a true PWM controller and will have much better control and torque characteristics than a router speed controller. Around $100 - $150
A good paper on the subject can be found here:
http://www.komel.katowice.pl/ZRODLA/FULL/84/ref_02.pdf
