New update:
The roll bar is in, but not painted, so no real installed pictures, the exhaust is in, but back out for transmission cross member modifications. The car was set on blocks that were a devil to level due to a swail in the garage floor. The pinion angle could not be set with shims because the perch bolts are too short, so the lowering perches were sectioned by cutting the welds on 3 sides, and then opened up to get the proper angle then tacked back in place for final welding out of the car.
The next project was to lengthen the passenger side wheel housing in the back, the driver side is long in the 67 because of the side fill for gas, but the passenger side is short. I will be running 10.5x28 slicks, the housing is 1/2" back on the springs for front fender clearance, but slicks grow, and it looked tight to the back, so we stretched it another 1 1/2. Now everything will be mocked up, a new Mark Williams drive shaft is ordered, the drive shaft loop will be installed when it gets here, then it will all come back out for cleaning, seam sealing, and painting, then re assembled. It still needs fuel lines, brake lines, E brake cables for the rear discs, and electrical.
The bead lock wheels will not pass reconstruction inspection here, so I added the new 295 MTs, and new rally wheels
