- Dec 24, 2016
- 12
I just wanna say that I made my cross slide dove tail for my Grizzly G8688. I just need to drill the holes in the cross slide but there's a guy on Youtube that did this mod for his Grizzly based on the Craftsman dovetail. Search "G0768 Compound Modification" and you can see what he did. It looks great and I look forward to testing it out but I can't see how it will fail. It's a wonderful design!
So how could this help you? Well I made the dove tail setup on the lathe just as the guy did and most lathe parts are built on a lathe so you should just be able to do this yourself? You do need a functional compound to make the dove tail but you could always take off enough material then use an angle file to shape a dove tail in.
With a carbide insert tool and 2" cold rolled steel, I had my all in one dove tail/base for the compound made in what would have been about 2 hours at n00b skill level with a pretty decent finish. With those cheap carbide tipped soft steel inserts, I had an extra 4 hours into it, tons of chatter, 3 tool breaks, and a terrible finish which I needed the inserts to finish and clean up the dirty work.
The only real problem was how close your tool holder and tool will be to the chuck teeth but with a lil care and probably a shop magnifying light, you'll be safe
