- Apr 20, 2019
- 169
Looks like a great project. I purchased their tangential tool holders and just the grinding rest (without the pantograph arm). I’m thinking the grinding rest assembly will be my third beginner project.
Why don't you use one of these? Put in the drill chuck. Tap after you drilled the hole. The chuck is in the right spot! Spring loaded tip goes in the top of the tap handle.Holes and M6 threads done on table plate
To get straight threads made, I tried using this... could not get it to work correctly...
So ended up going the old fashion way...
Because I took it to Ocala by mistake... so it is at the other house...Why don't you use one of these? Put in the drill chuck. Tap after you drilled the hole. The chuck is in the right spot! Spring loaded tip goes in the top of the tap handle.
Hello,
Any news on this one? Have you finished it and how do you like it?
Thanks for the swift update wachuko! I just stumbled across this one as I was yet again looking for device to start learning tool grinding. This one somehow appeals for a beginner. I would definately need some custom mini inside threading tools and in general everything in the quite small end of spectrum.
