- Aug 5, 2015
- 279
The project is to replace a telescope drive gear assembly. The current main gear has a 4 5/8 bore to attach to the scope. The replacement gear currently has a 3 1/2 bore. I have a 9 inch South Bend lathe.
My first thought is to bore a 'jig' the OD of the new gear to hold the new gear without munging up the teeth. If the jig is not removed from the lathe between boring the hole to hold the new gear and boring out the new gear center there there should be no alignmnet issues with the new center hole. The only accurcy issue will be the actual boring of the center hole.
Is this correcth thinking?
If the "new" gear with the 3.5" bore is mounted on a face plate with spacers between the gear and the face plate, you can true up/ indicate on the 3.5" bore, and just go ahead and bore it out to the 4 5/8" you need.
That is IF you are confident that the new gear teeth are concentric with the 3.5" bore. IF it is a new gear you will be OK, I think.
