- Dec 21, 2018
- 2,165
About particle board tops: The stuff sold at the big box stores is less dense/stable than the industrial board (48#s / cu. Ft.) But both are pretty unstable with changes in moisture. They are also quite compressible. Less than ideal for a machine bench. You can slow the changes by trying to seal the board. You have to treat both sides the same and especially the edges. If you don't treat both sides the same the panel will curl (even worse!) A laminated maple top would be better. Seal it with several coats of urethane varnish, all around. Best alternative: STEEL!
