- Jan 26, 2013
- 200
So here’s my dilemma. I’ve cleaned up the Y axis on my Bridgeport’s saddle and knee surfaces. It didn’t look too worn, still showed some flaking. So I took a light scraping to take down the obvious dings and high spots, knowing a more intense scraping would likely be in my future.
What I didn’t expect was when I test fit the saddle I discovered that the gib needed to go in about 0.350” more than the adjuster was capable of providing. That’s about .005” gap in the way. And naturally, when fitted snug it’s way too tight at each end.
Assuming that scraping things straight will make this gap worse, my question is: Do they sell oversize replacement gibs anywhere or does one simply add a shim between saddle and gib and call it done?
Looks like I’m also in the market for a good 24”-36” cast iron straight-edge, but even the raw castings seem a tad pricey.
