- May 27, 2016
- 3,477
Yup - now that I have started looking, it seems anything and everything is used. Kitchen wash sponges which come with a side looking like ScotchBrite, squished up hose, white plastic stiff foam from packaging boxes, inflatables, UniStrut nut springs, just about anything that can be stuffed in there to stop them falling over. I can see the utility of magnetic parallels.I like to use strips of metal strapping tape, bent into a "V", to hold the parallels in place. Free and easy. I also occasionally use them bent in shapes as 0.500 wavy parallels to miss drill holes. Take a Mic and measure the width. They're incredibly uniform along their length. Also, all 10 of my parallels have pairs of holes of varying sizes.
Wikipedia: Parallels: " Parallels commonly have a series of holes drilled on the 'front' face - allowing them to be used to position a workpiece or secured using t-slot clamps, and a countersink on each side to remove any sharp edges. "
Though a first purchase of the "most immediately useful" has thinner types, like 1/8" or 3mm recommended, there are some quite expensive boxed sets of 1/4", 3/8", 8mm, 10mm, 1/2", etc. For my own reasons, I had thought to get a pair, 150mm x 10mm wide that would be long enough to place right across the ways of my South Bend, and be wide enough to not just fall over. That will have to wait for a bit.
I can see the "wavey" sort as well. I have some reservations about them. I can see how adjustable parallels work. They have the property of being parallel, but lack being the same width, though can be adjusted so. I guess there are situations where they can be convenient.
