- Dec 29, 2012
- 394
UPDATE
After testing the unit it proved to be:
a. working more silently compared to the monoblock 2HP one I have
b. Smaller and easier maneuverable
c. provide a medium air supply and pressure, adequate for my small shop
I decided to add a pressure switch and some sort of air tank to it to make it more like an air compressor.
Two old 10 lt. fire extinguishers were used as air tanks
As my first effort to stick weld a 20 lt extinguisher created small holes in each welding spot I decided to clamp the pair instead of welding them to the base.
I used a stainless flexible metal hose to provide some cooling to the pressurized air before it enters the air tanks.
A small expansion chamber that collects humidity (water) that can be drained through a small screw at the bottom was also used.
And I have a silent small air compressor to use for small jobs.
Thanks for reading.
Petros
Thanks for reading.
Petros
