- Feb 1, 2018
- 1,867
Don't use grease as a lubricant, buy some Vactra 2 way oil. Grease will act as a lapping compound and catch the chips and dirt and ruin your new friend. Think about the gear as a bearing in your car, if it's to loose it will flop around. If the gear turned a little tight that is good as if it's to loose it will unwind. Make sure you didn't burr up an edge when taking it apart. Be sure to wear some Nitrate or leather gloves when you take it apart. Those imports have razor sharp edges sometime. Buy a small sharpening stone and stone it just to remove the sharp edges and burrs. I would not take apart the head-stock, carriage without getting the go ahead from Grizzly, as you might be voiding the warranty . As I said I would follow the MFG. instructions. I read on their website there is a warranty card, better fill it out and call http://www.grizzly.com/customerservice
The bad thing about brake cleaner is it can goof up the paint. Ask Grizzly what product they recommend. I hate to say this but I have never been a real big fan of Grizzly but I want to help you now that you have it. Rich
PS: Be sure to wear safety glasses when you use the punch and when you run the lathe.
