And the winner is ..... BLACK WRINKLE FINISH. I painted the first part today and chose the black wrinkle finish because it looks expensive and is durable.
I spent a lot of time figuring out the worm setup to get everything I wanted. This photo is the complete worm assembly. I had to make the eccentric and the hub to hold the index plates in two pieces and lock-tite them together . I cut the flats on the end of the shaft to hold the index handle and made a pretty brass hand wheel to hold the index handle on. I wanted it easy to remove to change plates. I also threaded the shaft and put a lock nut to hold the worm on.
View attachment 103309 This is the assembly of what is done so far. The worm mounting plate is painted and mounted. I should not have to disassemble it from the body anymore. There is a set screw in the back side to lock it to the body. It is also a kind of press fit on, so it will not move. it rotates with the body to go to the vertical position. You can also see the fancy brass hand wheel to hold the index handle on. There is a set screw assembly made up of a brass plug and two lock set screws in the front of the plate in the photo. This brass plug provides a little tension on the worm eccentric so it doesn't flop back and forth. It requires a light push to rotate the worm to engage or disengage and it will stay in position until it can be locked. The little 3/16" diameter brass lever sticking up is to engage or disengage the worm by rotating eccentric using this lever. I ordered a nice red knob for it from McMaster Carr. The gears turn very smoothly with almost no detectable back lash ( which is adjustable by the eccentric to be as loose or tight as I want.
View attachment 103316 This is a rear view. The "T" handle is the lock to secure the worm eccentric in position. You can see the trunnion sticking through the plate .150". Originally there was not going to be an outboard trunnion and I still believe it is sturdy enough without it, but I am putting one on. It will be a lighter weight assembly made from 1/4" steel plate. By having it , there will be the little extra support and make things that much sturdier and prevent vibration of the body hanging out there.
View attachment 103317 This plate is the outboard trunnion support. It is 1/4" steel plate. due to the close area of the worm mounting, the trunnion ring is not as heavy as the main support on the other end. You can see a narrowed section for 90 degrees that had to be relieved to allow the rotation to the vertical position. This assembly is heavier than it looks. When the ring is captured between the body and end plate, there is a total thickness of 1/2" of steel clamped up. It will provide more than adequate support on this end.
View attachment 103318 Here the trunnion is mounted. I still have to put the 3/8"-16 bolts in that clamp everything together. There will also be a heavy duty bracket to connect the second trunnion plate to the main base. I still have to drill and tap three 10-24 holes in the plate hub to mount the index plates. This will be done when the plates are made and all drilled at the same time.
In answer to the question asked about a cover for the worm gear to keep swarf out. YES, there will be a cover over the gear. I just haven't designed it yet and it will be one of the last details done. There will be a direct index plate behind the chuck with 24 and 36 holes in it and also marked in degrees. There will be a spring loaded pin to engage this plate when it is in use. I left that flat on the front side of the worm plate to fasten the spindle lock to. Yes, I will need a spindle lock . I also need to make a center and drive dog for working between centers. I have the material for it on hand.
I have tried to put everything in this project that the big honking 200 pound heads have. :
1.) a thirty to one gear ratio which will cover all divisions up to 50 and many others above using a minimum number of holes circles.
2.) 1 1/2"-8 threaded spindle that also accepts 3C collets and utilizes all my lathe chucks and face plates, giving me maximum versatility.
3.) the ability to rotate 90 degrees to the vertical position as well as the horizontal position.
4.) an easy to use eccentric to disengage the worm and allow simple indexing using a plate and spring loaded pin.
5.) A spindle lock to lock the spindle in position.
6.) easy to remove index handle ( no tools needed) and sector arms which will make plate changes simple.
7.) The unit is relatively small but heavy duty and fits nicely on the smaller mills such as the Burke. One person can carry it!
Have I forgotten anything?
