I noted the ball. I have been using them when I offset the tailstock to turn a taper. I made a set of centers to take balls .
I even make the rear "ball Center" offset.
Yes, I have also made up a few centres to hold a ball some time ago. That works well when offsetting work for taper cutting. The times when I don,t want to mess with the taper attachment, or the tail stock, I use the boring head mounted in the tailstock, and also have ball centres to fit the boring head also.
Using a ball to hold down the manifold as shown in the video is a quick and dirty approach that works well. The ball trick can also used to tighten up a hole that the reamer took out a thou or two over. I just drop a ball on top of the hole, and giver a swift swat with a hammer, the pin will fit nice and snug as it should, works good.
