A degree wheel for the Atlas/Craftsman 6X18
Okay, I'll draw up a couple of marking strips, one for each direction, and post it here when I'm done. In the meantime, I suppose one option would be to use a simple tape measure.
If you took an 'inch' tape measure, marked in 1/16" increments, you could cut out maybe a 1/4" wide strip of the edge that has the individual markings. Then, at 1/16" per degree mark, that'll be 360/16 = 22.5" for the circumference, which would wrap around a 7.16" diameter wheel.
Or, use a metric tape measure, with 1mm per degree, that'll be 360mm (14.173") for the circumference, which would wrap around a 4.51" diameter wheel. You could even leave the numeral markings on it (which would be in centimeters), and add a 'zero' to each number.
Or, you could get some automotive adhesive-backed pin-striping tape, and meticulously mark each 0.050", which would give you a 18" strip for the circumference, which would wrap around a 5.73" diameter wheel. Or find some with preprinted markings.
TapeMeasureInch.jpg TapeMeasureMetric01.jpg TapeMeasureMetric02.jpg MagnaTag-TPcover.jpg
If you can't do the scale big enough on one sheet of paper make it in parts .
Decide the diameter you'd like for the indicator disk/wheel ( it may well be slightly different at the end of the exercise ) .
Then use Pi times Diameter = circumference . Pi being 3.142 or 22/7 to five or more places if you feel like it .
Adjust the diameter so the circumference is exactly divisible by 360 so you can design a scale in degrees . Make it so you can clearly identify one division per degree .Turn you disk to the exact diameter needed . ( check your figures a couple of times )
Use eXcel of similar to make & print off on two exact scales with numbering and bigger marks at the five & ten degree points . make the scales in 180 degrees or three of 120 degrees or four of 90 degrees , glue & tape them in carefully place on the disk or use a big heat shrink band etc etc. .
Take care with plastic paper or surveyors flat steel tapes etc they might been made in China or India etc and leave a lot to be desired wrt. accuracy . Self adhesiv tapes tend to stretch how ever there are some failry accurate wood working device adhesive strip measures that might be useable as they tend to be on a strong plastic metalized backing .
I'll have a look on line for the sort of thing I'm thinking of . An 18 cm long one would be a bit of a small indicator disk but several could be a whole new ball game
eBay item 111483477188 is a Starret metal flat tape in imperial & metric which are usually fairly accurate at 60 o F
So 360 mm .... 36 cm in divisions of one five & ten making 360 millimetres ) being a circle in degrees sounds ideal
3.14258 pi to 5 places x 114.52 mm diameter =359.91918 decrees or as near as dammit 36 centimeter
114.52 mm / 25.4 = inches diameter = 4.5087 inches to five places
22/7 is an approximation. Pi to five places is 3.14159
Robert D.
Wow..... this is fascinating. I been racking my brain trying to get this stupid computer to scale me a drawing or even make one and can't do it for some reason.:eek:uch::whiteflag: ( well, could be i ain't smart enough. I get dumber as I get older.). Maybe I can work with some of these suggestions. thanks guys.
Mark Frazier
I don't really care about the diameter. I just want it as large as I can which is between 4 and 6 inches somewhere and I want it to look nice. That why I want to print it , plus I have magnetic paper (heavy) that is also very sticky on one side and I can run it through my printer. I have 5 inch round steel I can cut down to a needed diameter.:pondering:
Robert D.
That's interesting Robert ... I was taught at the Electrical & Mechanical Engineering Apprentice college that I attended for 3 yrs was that 22/7 was the right equation that's why it never works out as a decimal .
I'm intrigued , can you point me to any places that explain how it is derived please? .
Thanks for that John ...my head .....it's going... going "Round in circles.
By the time I'd speed read to about half the reference ... I nearly lost the will to live :lmao:
It's interesting to see that there are so many new accuracies for it . I'd never heard of anything other than old Archimedes way as being 22/7 .
It only goes to show that you can learn something new every day ( especially if you suffer from the early stages of Alzheimer's like I seem to do :rofl:).
I give up :whiteflag: . I just spent 5 hours trying to print a scale from several software programs. I got close , but me and this computer are not getting along.:banghead::banghead: . I'm going to the shop and do what I do best, cut metal and make chips. I got along 45 years without a degree wheel , I guess I'll make it till I die without one too.
Mark
