- Mar 17, 2018
- 1,400
If you are looking for a mirror finish use a fly cutter with a freshly sharpened tool in it. I agree with an hour or less while taking my time.
I agree with this if you don't have the bucks to invest in a quality 4" face mill. This tool is really great and decently priced - it fits in a 3/4" collet. If surface finish is your goal, and you don't have hundreds to make, I would actually use the insert specified for use with aluminum on 1018 with something like a 0.002" DOC - you'll burn up the inserts twice as fast as the one designated for steel, but the finish will be amazing. And with 4 cutting edges per insert, that's not super expensive.If you are looking for a mirror finish use a fly cutter with a freshly sharpened tool in it. I agree with an hour or less while taking my time.
Hi All
So pictured below you see to mild steel blocks. The one on the left is cut from my bar stock without anything else done to it. The one on the right is a "finished" blank. Later it will be milled into my guitar bridge.
Stock block
L 2.92"
W 1.668"
H .986"
Finished blank
L 2.79"
W 1.625"
H .955"
My comparison here is a question. How long would it take you pros to turn the block on the left into the finished blank on the right?
I have added into the pic the tool I use to do the above. I get nervous about heavy cuts with these little circular blades on the tool so I only make at most .010" cuts.
I run the tool at 1000 RPM's. (I usually start with .005" cuts until the patina is off then I go to .010" cuts, and I use my x axis powerfeed running slowly.)
When I get within .010" of my final dimension I then go to a .005" pass, then a .003" pass, then .002" pass and finally two .001" passes at double the speed.
My goal with the small cuts is to minimize the depth of the swirls because I do the real finish with hand sanding.
I'll share with you later how long it all takes me. For now I'm curious and I would love to know how long it takes you pros to make the finished blank.
My ownSeems you got some pretty sound answers. Now we want to know what brand of guitar!
Nice breakdown.7-10 minutes on the band saw to get the blank
2 minutes with hand file deburring edges
Large sides on the blank: less than 10 minutes
small sides on blank: less than 5 minutes
Coat scale liberally with heavy cutting fluid each pass
Touch tool off on part,
first cut 0.010-0.020 deeper than the scale.
1/2" carbide end mill, climb cutting around the edge then onto the center (saves deburring time between sides)
Finish with flycutter taking 0.002.
You are cutting with the very edge of the carbide insert. By getting the edge mostly under the hard scale, the edge doesn't wear as much as it would if trying to cut directly through the scale, instead you are peeling the scale off.Can anybody further extrapolate on that "scale"? My assumption is that its harder than the steel underneath. If so then why wouldn't I want to take shallower cuts with it than what you all say, a deeper cut? Not wrapping my head around that one.
Ah, I can see that. Makes sense and thank youYou are cutting with the very edge of the carbide insert. By getting the edge mostly under the hard scale, the edge doesn't wear as much as it would if trying to cut directly through the scale, instead you are peeling the scale off.
