- Aug 19, 2023
- 1,059
To be honest, I would rather use a grease gun with a fine tip over a syringe. At least you could swap the tip to then hit zerks with.
So I just changed the oil in my headstock and was greasing the gears and thought "there has got to be a better way!". I've been using the digital method, which is to say that I get some grease on one of my digits and apply it to the gear teeth. This is messy, not just in operation, but in the grease that gets slung off in operation. (Inevitably some teeth get huge amounts of grease which is wasted as opposed to distributed as you might hope in an alternate universe.) So I thought I'd ask and see if any of you clever people has found a better way?
TIA,
GsT
+1 I finally got myself a Dualco grease gun and it is joyous to use thanks to the interchangeable tips.I would rather use a grease gun with a fine tip over a syringe.
I use that as well. Works good for me.I don't use grease. I use spray on mototcrycle chain lube, the wax type.
