I like this idea but there is barely enough room between the shaft and the block that holds the feed lever.The shaft extends out the front of the apron to get a cir-clip on to hold it in. The clip is the problem, under load it will come off. I did away with this by drilling and tapping the front where the cir-clip is. I turned .010 off the front and added a washer under the screw. I have had no trouble since.
"Billy G"
Another thing I did do that helped the feed was to add washers behind the gear splines of the pinion to enable more of the thread to engage the rack.
So Bill, how about a thread listing all the mods you performed and how you did them to improve this lathe.
I know there are sites around but something along the lines of Cletus's booklets where all can add any type of improvement small or large.
I would love to add brass STRAIGHT gibs to all the slides instead of the flexi skinny metal there at the moment but dont have a means of milling them.
Back to folding the bellows, just an experiment that is too thin as hot swarf will more than likely burn through it but its a start for a better material.
