- Aug 22, 2012
- 4,264
I'm unsure if it was my fault or the machine.
I had two aluminium flanges bolted together on the faceplate with spacers so I could turn the outside dia and bore the inside dia parallel with each other and both end up exactly the same.
All was going well on slow auto feed - bore, disengage the feed lever, wind back to start, wind out the cross slide for next cut, engage feed lever and so on.
Only taking light cuts as I didnt want to overshoot the bore dia.
on the sixth cut I disengaged the feed and started winding back to the start when everything jammed solid, anic:thank you clutch. I switched off as fast as possible.
I had to dismantle the apron and lead screw whereupon I found the following mess."jawdrop:
It looked like the sliding key had come out of the leadscrew and jammed in a heap of swarf.
I've never seen such a mess.
Is winding the carriage back with the power feed disengaged but the lead screw still turning a no no?:whiteflag:
The shaft that the worm turns is bent but that appears to be the limit of the damage, the leadscrew is still straight.
I just hope I can get a spare as I dont believe I could make one.:help:
On the bright side (well I'm desperately trying to see one) I found the reason why the half nuts disengaged occasionally when threading.
Once this is repaired then some serious anti swarf shielding is being made.
