Here is what I did with my PM935 that arrived last week. I wanted it up on leveling feet and to increase the height of the machine off the floor just enough that my pallet jack forks would clear going under the mill from the side (forks are 21" wide, 3.5" tall, the cutout is 24", but I needed another 1.5 inches of height for them to clear).
I started with two pieces of 1/4" thick 3x4 angle, 26" long, clipped off the 3" side corners at 45-degrees, flap-disc'd off the mill scale and radiused the corners and eased all the edges.
I ordered 3" diameter leveling feet from McMaster 6111K247 - could have gotten away with the 2" high versions instead of the 4" versions I ordered. These feet are 3/4-10 thread, come with a locknut, but no washers or other nuts (which I ordered separately).
I decided to use 5/8" AllThread to attach the angle plates to the mill through the holes in the base of the PM935, and set the leveling feet outside the base of the machine to improve stability. 10" long all thread into tapped 5/8 holes (which are 417mm apart CL-to-CL), the leveling feet were placed 60mm in from the end of the angle brackets:
After drilling and tapping, I primed and painted the angle brackets:
After two coats, and installation on the PM935, this is what the finished platform looks like. The 5/8 AllThread fits the 3/4" holes in the machine base just fine. I will probably end up trimming off the tops of those once everything else is settled.
Since the floor here is 1.25" T&G commercial decking plywood on stringers, my plan is to drill out 4" diameter holes in the floor and put in 4" diameter solid aluminum round bar stand-offs that will go down to the concrete floor below, turned to match the height of the floor. I'll post on that once finished. And it's also time to re-paint the floor, obviously.
Hope this helps.
