- Aug 22, 2012
- 4,260
I came into possession of a matched pair of Jaeger 83mm dia lens of f15 focal length.
Although a focal length this long is somewhat against current practice I thought it might make a good project.
As this project is a long one I thought rather than just put the odd bit in the “what did you do in your shop today” I would do a complete build blog in case it might be of interest to others.
I started by making a 3d model with the full light cone to give me all the dimensions and hopefully how I could fit it all together.
Most amateur telescope makers start with the scope then go on to the mount.
I wanted to check out a few things so opted to start with the mount first.
So a quick render of how I wanted the feet.
And the following welded structure came about times 3
Todays job was drilling and tapping the end for the eye bolt.
The screw and knurled knob is to angle the leg downwards to adjust the central pier to sit perfectly vertical.
