- Jan 9, 2016
- 120
Hello all,
Absolute newbie here in the metal world. I just bought a used 7x10HF lathe and currently have it stripped down for cleaning and whatnot.
I'm planning my first project: a powered drill press table lift for a 1950's-ish Craftsman drill press.
I'll be using a 3/4"-6 x 24" acme threaded rod to move the table up and down, powered by a stepper motor and control board.
My question: is it reasonable to turn the ends of this rod down for (bearings and drive couplers) using the 7x10 lathe? I have purchased the LMS 4-Jaw chuck (plenty of clearance for the rod to pass through it and the headstock), and am planning 2-3 outboard supports (steady rests?) for the rod to the left of the headstock.. Supports will likely be plywood construction, HDPE bushings, and will be anchored to the bench with through-bolts.
I would like to turn each end of the rod down to 3/8" or 1/2". The bottom end of the rod will sit on a thrust bearing (requiring a nice, square shoulder) and be connected to the stepper motor with either sprockets and chain or some shop-made delrin gears. The top end will also be turned down to 1/2" to fit in a bushing.
Thank you,
Jay
End note: There will be a lot of baby steps between here and there. I have a ton of research to do, lots of practice cuts to take, etc. It will be about a month while I'm cleaning up the drill press (recent CL purchase) and getting the piece drawn up, plans finalized, etc.
Thank you,
Jay
