Your 7x10 profile seems to be using the Mach3Mill screen and moving the axes correctly(though both are backwards-Z should go positive as it moves away from the headstock, while X should go positive as it moves toward you(away from the lathe centerline), while the mach3turn profile is using the correct Mach3turn screens, but moving the wrong axes.
I see that you do have the same port/pin set for the axes in both profiles, which seems to indicate that one of them is corrupted, but it would be helpful to know which DRO on the mach screen changes when the axes move in each setup. It is possible that Mach is working perfectly but that there is something wrong in your pendant setup-how is that pendant attached? Is it USB, serial, or another method?
Why are you using 2 different profiles? Pick one of them, and get it to work correctly. Do you know how to load a screenset? Since your 7x10 profile is moving the correct axes, I would just load the mach3turn screen set in that profile, and call it a day.
Andy
