- Aug 14, 2016
- 20
The spindle wasn't even close to being parallel with the ways. A close inspection shows cracks on both sides of the bed. The crack are in line with the chuck side of the headstock housing. Playing with shims under the lathe legs I got the vertical offset down from 0.023" over about 8 inches to about 0.09". That took about 3/16 worth of shims under the foot pretty much below the cracks. The horizontal offset was better, but is still off about .006" over 8 inches.
I'm beginning to believe the only way to get the lathe where I want it to be is to replace the base and the cost of that makes it more likely that there will be a modern mini lathe in my future.
Thanks for everyones ideas.
