- Jun 18, 2020
- 31
@ErichKeane - After reading your overview on grinding it sounds simply enough to give it a try. I'm going to order some blanks and give it a try. Its something I'm going to have to learn anyways. The pre-ground tooling you referenced looks reasonably priced so I can practice with those.
@DAT510 - Yes, all the inserts are CCMT. For the ISCAR CCGT 2-1-AS what speed/feed are you running when your turning ALU? May be worth a try and see how it performs. I appreciate the close-up of the insert.
Thank you to all for the comments and suggestions. There is so much to learn but I guess we all started at where I am today. I'll keep at it!
