- Jul 28, 2017
- 2,572
Since the blade guides add their own twist to the situation (pun), presumably blade life is a bit adversely affected by that. Presumably blade life is also a little bit affected by being used. If the blade life is not so great under the best-possible conditions, why wouldn't you be concerned?Call me cynical but I'm having a hard time giving a rat's arse what the blade life is when not following the guides that make it square to the work and not cutting anything. A previous post mentioned no tension spring but my HF 4x6 has one. I have no real way to measure the tension other than seat of my pants but I keep it set on the heavy side for narrow materials and just add weight to have the proper tooth load when cutting a larger footprint.
