I used a 4x6 Harbor Freight bandsaw for several years for light commercial work. It finally started having failures, and I also started running into more and more jobs it was not big enough for. I finally decided I need a bigger saw. After much shopping around and atleast one false start I started looking at Harbor Freight again. Not because I wanted cheap, but because I needed it now, and Precision Mathews was out of stock. The HF 7x12 is still shown on the website. but I had not seen one in the local store in a couple years. I was about to buy one off their website with a 20% off coupon code when I decided to call the local store. It turns out they do stock them. They just don't display them. I had to pay city sales tax, but I saved freight. Saved me about 50 bucks right there. With the 20% off coupon the saw was a lot cheaper than any other option in that size class. I expected a clunky upscale version of the 4x6, but when I started unboxing and setting it up I was very pleasantly surprised. It may not be built as well as some of the other imports, but this saw is very much a better than average quality saw for harbor freight. I've already used it for cutting 4140HT flat bar, angles in A36 steel tube, round 4140QT, and aluminum flat bar. Absolutely no issues, and the pneumatic feed perfectly. Before I ever rolled it inside the shop I plugged it and did a test cut in apiece of 2" EMT. With the pneumatic feed set I barely even noticed a change in pitch when it transitioned from the wide entrance cut to the thin cuts on the sidewalls of the tube. I've had it for a little while now (couple weeks maybe) and its not at all new tool glow. I still like it very much. Its definitely a better quality tool than the 4x6. I wish I had bought this one to begin with.
Other notes.
1. It can be setup for 110 or 220. Mine came setup for 110V. I may switch it over to 220 down the road, but I have not decided where its permanent home will be yet.
2. If you want to run coolant it comes with a coolant pump and reservoir. I have not used that yet. My shop is messy enough, but after it finds its permanent home I might.
3. The 1HP motor on the 7x12 is physically larger than the "1HP" motor on the 4x6. I suspect that means it either has larger windings and/or that it really is 1HP. Those are both good things.
4. It is larger than the 4x6, but not all that much. Takes about the same amount of space as a decent roll around air compressor.
