4th axis harmonic drive build
Looks awesome! I'm looking forward to the finished project and I'd be curious to know what kind of backlash you end up with.
Thanks! I really enjoyed watching that. I'll be wanting to make one myself prrhaps albeit a little larger.
Jay, that's a great design and write-up/Video. A while back I converted a rotary table to a 4th axis but your concept is so much more compact and better. Thanks for sharing. Bob
Great
Videos Jay! I Enjoyed them tons!
Looks like what I need too do but maybe just the next size up on the harmonic gear..Or is that gear sturdy enough to handle an 8" chuck? I need to use a servo on mine and was thinking about belting the servo to the gear so it would not be so long..it would just be more thick..wrap around kinda thing.
Great
Glad you liked the videos. If you follow the link to my web page there's more info about the harmonic drive, including a link to their "catalog" that has specifications for different models of gearboxes. They give specs for various kinds of applied loads, so that may help you determine which size is sturdy enough to handle the loads you want to apply.
Using a belt drive is definitely a tradeoff, potentially making things more compact and giving you the option of changing the ratio with the pulleys. On the down side, it will sacrifice some rigidity and positional accuracy. It's hard to say how much would be sacrificed since it depends on the construction details, but anecdotally I see that timing belts are commonly used on 4th axes for woodworking applications but are much less commonly used for metalworking. Or perhaps more to the point, belt drives are commonly used for decorative applications where tolerances tend to be loose or even nonexistant. I'm not saying you can't get good results using a timing belt, but if you want to do something precise like gear cutting then a direct-coupled drive may be preferable.
The X & Y axis on my PM-932 CNC conversion are driven by timing belts. No rigidity or positioning issues.
May I had my thanks also. Enjoyed the build , something to strive for. At this point all I can do is watch and hope for the future.
