Cast zinc is totally different..... And I think what he is talking about is White metal or pot metal. Thats the really cheap cast aluminum.
If you have that, you can still weld it but the results will not be very good and it will be a pain in the butt.
On cast aluminum you ONLY will every use AC and NEVER use the puler. Pulsers are typicly for people who do not know what they are doing and it takes about 20 years of quality tig welding to figure out how to properly use a pulser. If you or any one use the "Plulser" to make puddles, then your way off on what it is and how its used. No pulser, AC current only and adjust the ac balance for more cleaning. If you do not have AC balance then it makes it a little tougher to weld cast.
I have to not realy disagree with a couple of things but can add to our welding toolbox. I have 31yrs helmet time as a TIG welder, called when I
started "HeliArc". 12yrs of that 10hr day factory, the rest short run fabrication and repair. Lots of cast aluminum. Miller 330 A/BP as
my main machine, It's a balanced wave transformer. Here is what I use the pulser for on cast aluminum and why. With my inverter machine.
You have a dirty casting like a head or oil pan. You end up adjusting your AC balance close to 50% to get enough cleaning action from the arc, for
the dirty casting anyway. Like not having any AC balance to start with. Here is where AC is used with pulse, you back down your AC balance for
a little less cleaning action but more penetration. set your pulse with only 20% less background current and frequency around 200-250hz.
What that does is it agitates the puddle and shakes the dirt and impurities to the top. The other benefit is it focuses the arc tighter like
increasing the AC freq without cutting down the cleaning action. It also concentrates the heat in the weld area a little better before the thermal
conductivity of aluminum spreads it out and warps your part.
"Pulsers are typically for people who don't know what they are doing" Where I disagree with this statement is, "typically for". If a new welder uses
the pulse tool without starting with base settings there learning curve will be extended for a VERY long time. If an experienced welder sets up the pulse settings for them then I completely agree with that statement. As it can be a crutch. As in a factory setting where they are unable to find
TIG welders with a solid base, but is used to get product done and out the door. But there again it is a tool for the factory to use and up
production, the bottom line.
The pulser is just another tool in our tool box. People that have a lot of experience, still will pound on a screw driver with a hammer. Just another
way to get the job done. It's your screw driver. I won't curse you for it but might offer a suggestion.
Have a enjoyable Labor Day
Take Care,
Rick
