- Oct 7, 2020
- 94
So, I went through the first 1/5"-ish in good time. As soon as I got to a depth where the teeth were almost completely inside the cut, it stopped cutting almost completely. (The band is 1/2" thick, and it looks like it's maybe 4-% of the way in the cut, but I can't think of a good way to measure into such a small width groove.) There is no more steel being removed as far as I can see-- no dust on the bar itself, no dust on the saw guard, etc.
How much weight should I be applying? I know the stationary band saws use their own weight to cut through, but I assume they weigh a good deal more than my portable. Should I be pressing firmly down? Putting body weight on it? I did press as firmly as I dared, but maybe that wasn't hard enough?
Also, the blade seems very firm when the saw is not running-- I can't get any play on it at all, it seems to have great tension. But when it's running, it flops both to the left and to the right when it's in the groove. Is that normal?
