35 vs 72 piece Collet set?
LVLAaron
Oct 4, 2020
484
Need a complete collet set and looking at these:
I know twice as many is twice as good - it's also twice the cost and twice the space in my shop. There's not much info on the site - does anyone know the size tolerance these collets have? Should I get the full set? I'd be really cranky if my first project that needed a collet was an inbetween size and I had to go find one online :)
Even 1/64th steps in 5C doesn't cover the entire range. Have look at the attached (especially pages 7-9). If you want to be able to workhold any random diameter up to 26mm, you might be better off with ER40 instead of 5C (or in addition to).
  • About R8 ER and 5C Collets.pdf
I would definately get the bigger set... I bought the 35 piece set and regret it...
Unfortunately, as far as I can tell, I can't buy just the 64ths collets as a set... to get them, I would have to buy a full 72 piece set (and have duplicates of the 35 that I already have), or buy them individually, which is significantly more expensive.
I'll eventually buy a 72 piece set and try to sell the 35 piece set...
-Bear
Thanks that was helpful. looks like ER40 is a little less expensive as well.
I'd stick with the 5 C set, as there are likely more fixtures that use them.
Huh???
I ended up ordering both... 5C and ER40 chucks...
Have not ordered the ER40 collects because I can't remember if it was better to order the metric ones or the SAE... I remember reading a thread on this that suggested one over the other as it would work fine without having to buy both sets...
You're very welcome.
