I bought my Smithy 1230 off Craigslist and got a lot of tooling with it for a super deal. Is it a great machine? Not really. It's an acceptable lathe with a usable mill attached. Can you do a lot of stuff? You bet! For example: http://www.hobby-machinist.com/threads/im-making-a-halo.28708/ Would I like to have a real mill and lathe? Yes. If I get a real mill and lathe, will I keep the 3 in 1? Yes. So, to get started, get your feet wet, see if the hobby is for you, then I think getting a used 3 in 1 with tooling is a great idea!
Best regards
Dave
I am not in a hurry, but am checking at used and new mills, what kind of deal I can find. I am less interested in a lathe for now but would get one down the road.
I have read many posts, the majority are against 3 in 1 machines for various reasons....compromise and not really good at either, underpowered, too small...etc. I m looking at a small mill, like X2 or X3; anything much bigger becomes a problem for space, budget, or transport for a decent used big machine. For now, I want to get into machining with something small and see how I like it. If I get the bug, then down the road I'll see about bigger and better.
I ask about 3 in 1 because there are a few used machines in my area, there are 2 different people selling an Emco Maximat V10p. Then a 3rd machine which I am not sure what it is, I would need to contact them for more info.
Also, Smithy has some great deals on their 3 in 1 till April 30 + free shipping (in the US). I read on the Smithy thread, most that have a Midas are not too happy and would not repeat their purchase. Those that have Granites are generally more happy and find they can accomplish quite a bit.
I have been looking at the Granite Max, one up from the entry level Granite; the same power as the 2 higher models, minus some bells and whistles.
https://smithy.com/granite-max
Any opinions on the V10P's, terrible, mediocre, or better than most 3 in 1 machines?
Then the Smithy Granite Max, with about $1200 off till the end of the month + free shipping to a place I can pick up in the US; decent machine for the money or money better spent elsewhere?
For anyone that is going to ask what I will be making, not sure, looking to get my feet wet for now.
I don't know what is available in Canada, but here in down under land, all the 3 in 1's I can find are Chinese junk. I did have the pleasure some years ago while working as an engineer on a ship. the ship was fairly large 136,000 T crude oil. In the main workshop we had this lathe which also had milling capability and surprise, surprise a small shaper.
the lathe, I don't recall the brand, may have been Mitsubishi, the ship was built in Japan by Mitsubishi, and most of the equipment carried their name.
This lathe was unusual for 3 in 1, as all the accessories were outboard of the headstock , not inboard as most are. The lathe itself was first class. from memory it was about 1440 in size, 3ph, 5HP. The one motor ran all functions, and the lathe could be used while the shaper or mill were in use. each accessory was operated by its own clutch from the main motor.
There were mechanical and electrical lockouts, for instance you could not engage the clutch for the shaper if the table was not low enough to clear. you could not raise the table if the shaper was not stowed and locked.
The mill had both horizontal and vertical spindle. the mill table was on a knee, and when wound well down the shaper head was exposed, the shaper using the mill table as it's own.
I tried to find such a machine before buying my lathe, but could not find anything like it. I would have been prepared to pay a good price for one. In the end I bought the best lathe I could to fit the space available.
I'm planning a project to build my own vertical spindle mill, mounted over the bed, Hopefully I will have made enough progress to post some pics in a few months time.
I bought my Smithy Midas 12x20 lathe 11 years ago and while it does have some limitations I have loved it! I will list the pluses and the minuses below and you can go from there.
Pluses
1) Great support by Smithy. First week I owned I broke one of the change gears. I told them what I did and they sent a replacement free of charge.
2) great size for the money
3) pretty darned accurate! I have held tolerances to within .0005" on the lathe
4) smooth finish with the two power feed speeds
5) will hog through tough metals on the lathe without too much difficulty.
6) belt drive so some sort of crash protection for while you learn what not to do.
7) tooling from Smithy is reasonable (example 4jaw Chuck was around $200)
8) adaptable with minor modifications (quick change tool post)
9) free tooling included to get started and decent too!
Minuses
1) milling head is not very rigid so light cuts are in order.
2) only two speeds for power feed.
3) no threading dial
4) no power cross feed
5) milling vise broke after milling some heavy cuts in steel. My fault for pushing the vise beyond its design.
I have made threads on it and while it was a pain to do it will do them but you must be patient and methodical about it with plenty of foresight into what you're doing. I have made a lot of parts for cars and some airplanes as well with it and have been very pleased with it.
Here recently I had to tighten up the spindle head bearings a bit as I was getting some chatter in my finish but since I have done that (not a hard job to do btw) it has been flawless again.
I would not hesitate for a second to buy another machine from Smithy.
Call them and they can usually set you up with someone in your area where you can go and meet them and see the machine in person and talk about it. I have shown my machine to several people over the years and some have bought one and others haven't. And there is no incentive for me to show it to someone when smithy calls me and asks if I mind showing it.
Hope the above helps.
Sent from my LGLS991 using Tapatalk
Check out this website for examples of work done on Smithy 3-1 machines. http://www.home-machine-shop.com/projects/
