the sewing machine motor showed up today and i'm impressed so far...
it says servo motor but i dont see a sensor for controlling motor speed on the shaft?
so for now i think it is just a variable speed dc motor
the pedal switch for speed is controlled by a magnet on the lever, the closer the magnet the faster it runs. so it can be moved and redone as a switch or variable resistor. or a threaded rod to pull the lever to what ever speed.
the dial setting for max speed is a switch with resisters solidered across each contact giving presets the lower the speed the higher the resistance. it can be replaced with a pot (variable resistor)
the motor has just 2 wires coming out of it so the controls can all be moved but should have a fan installed if moved.
i believe i can control this motor from mach3 by replacing the magnetic sensor with a motor controller card no problem
direction is a simple switch reversing motor polarity.
removing the foot pedal lever also removes the mechanical brake but an electrical brake is easy with a resistor and relays.
i have not bolted it to anything yet but i think i'll do a drill press first
the motors housing is threaded, so other mounting is possible pretty easy.
until i take it apart further i dont know the variable resistor or voltage requirements to control the motor but i will post them.
I want to test the motor for power availability/limits before disassembly
steve
[video=youtube;92OrGyPIt70]http://www.youtube.com/watch?v=92OrGyPIt70&feature=youtu.be[/video]
this is the inside of the controller. top center resistors around max speed selector switch. right side ,magnetic sensor speed 0-max setting
