- Sep 8, 2019
- 4,392
I thoroughly cleaned all 3 of my machine tools.
Then I figured out the taper attachment on my PM-1660TL. It took me awhile to figure it out. I was told that I would have to “disengage” the set screw that serves as the cross slide backlash adjustment. I did not find that to be at all relevant.
What DID work was to loosen 2 allen bolts at either end of the “pivoting angle adjustment lever” in order to select the taper angle; then tighten it in the desired position.
From there it is only a matter of tightening the brown thing that looks like a carriage stop (shown in the first photo). Tightening this forces the carriage assembly (which includes the cross slide) to “engage” and move along the taper attachment. The base of the taper attachment remains fixed while the top manipulates the cross slide as the carriage moves.
All 3 of the bolts in the photo above need to be tight for the taper attachment to engage.
I didn’t see that you need to mess with the 5 bolts below. I only see these are a way to adjust the cross slide backlash.
I got this to .0253”/inch when I was looking for .0256”/inch so I will call that good.
One final note about that brown thing that looks like a carriage stop: when the taper attachment is not being used, the bolts on the brown thing are loosened enough to allow the entire taper assembly to move back and forth with the entire carriage.
This is where I have it set for Morse Taper #6 1/2:
