- Jul 29, 2014
- 2,861
I saw a YouTube video on making single triangular insert dovetail cutters, looked like an interesting project. So I had some random metal around and just kind of hacked these two pieces out, one 1/2” shank and one 5/8” shank. Why different sizes? Ummm, kind of missed my target the first time, which became the 1/2”. The inserts are TCMT something or other, they were parts bin pieces. And suitable for “what did you buy today” I needed a 2.5mm tap for 5he insert screw, and found this kit of small metric taps for about $12 on eBay. They claimed HSS, and sure enough, no problem at all tapping the dovetails...one is 303 stainless, the bigger is a mystery metal. You can see a finish difference.
I tried them on aluminum, and was impressed. Seemed at least as good as the multi-fluted cutter I had around.
The cool trick I picked up from “this old Tony” I believe, was making a pointer tool to chuck up in the mill, just the diameter of the insert hole, and push the insert around in X and Y until it’s located perfectly. That’s the zero point for drilling the screw hole.
